Jerehmy
- Aug 23, 2013
- 415
If you look at table C4.2.2D in ANSI/AF&PA SDPWS-2008 ( for 10d common nails the maximum fastener load for calculating nail slip is 260lb (this is for deflection, so ASD loads).
If you calculate the fastener strength for a 10d nail connecting plywood into framing (assuming the plywood's specific gravity is 0.5 and framing also), you get the following load from Table 11Q in NDS 2005 multiplied by 1.6 wind factor and 1.1 diaphragm factor:
15/32" plywood : 88*1.6*1.1 = 155#
1" plywood : 118*1.6*1.1 = 208#
1-1/4" plywood : 118*1.6*1.1 = 208#
What am I missing? Why would they allow for a 260# maximum fastener load when in no situations is that plausible? I must be missing something.
Thanks.
Thanks.
