GA_Engineer
- Jul 9, 2021
- 14
I have a few questions on what others do in calculating the deflection of a wood shearwall. In my specific case I am looking at the deflection due to wind.
1. In the 3-term deflection equation in SDPWS, it uses Ga (apparent stiffness). For seismic conditions this value is given in the nominal shearwall capacity table. However for Wind it is not given. When checking deflection for wind do people generally use the 4-term equation per the SDPWS commentary or just use the stiffness given for seismic for wind as well?
2. Within the equation for shearwall deflection, we must take into account the deflection/elongation of the hold down/anchorage at the end of the wall. For the hold downs at the foundation, this is given to me by Simpson for the hold downs required. However , I have a multi-story condition with strapping between floors at the end of the walls. Where can I find the values for straps as I’m not seeing it in the literature?
