bassplaya69er
i am in the process of working the kinks out of a DIY post i've made for a BOSCH cc120 used to control a router.
i use G54 - G57 as references for the 4 corners of the machines bed, and regularly use 54 and 55 when flipping a sheet over to machine on both sides.
i have a custom command in my post to output the fixture offset +53 and to stop the machine and move to a position for easy loading.
the custom command is placed in start of operation.
problem is this outputs the reference in between every operation, which is quite annoying when on G55 !
i have tried puting the whole thing in to something like: "if {$workoffset != [expr $mom_fixture_offset_value +53]} type s
#Set work offset & stop machine to alow for part repositioning at G55 and above
global mom_fixture_offset_value
global workoffset
global workoffsetchange
set workoffset [expr $mom_fixture_offset_value +53]
if {$workoffset >= 55} {
MOM_output_literal "M05"
#Stop spindle
MOM_output_literal "M09"
#Raise Head
MOM_output_literal "G53"
#Switch to MCS
MOM_output_literal "G0X1220Y1220Z0"
#move to loading postion
MOM_output_literal "M55"
#UnClamp Right
MOM_output_literal "M57"
#UnClamp Left
#MOM_output_literal "M51"
#VacPump 1 off
#MOM_output_literal "M53"
#VacPump 2 off
MOM_output_literal "M00"
#Stop program
MOM_output_literal "(FLIP/REPOSITION STOCK TO G$workoffset)"
#Operator message
MOM_output_literal "G$workoffset"
but im guessing the global variables are only global to the custom command, not the whole post?
anyone have a good idea of another way around this?
i would also like to change stop conditions, so rather than being >= g55, it will stop on the first offset change, allowing me to use G55 as the first side and G54 as the second side, purly for flexibility realy.
any help very appreciated.
global workoffset
#Stop spindle
#Raise Head
#Switch to MCS
#UnClamp Right
#UnClamp Left
#VacPump 1 off
#VacPump 2 off
#Stop program
#Operator message
