Anyone notice the new Diesel Land Speed Record of 350 mph (563 kph) just set by a Andy Green from England? There's some amazing numbers, including 10.5:1 compression.
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Ricardo calculated that for the speed record attempt, the two engines would require an intake airflow of almost 5 tonnes per hour. Moreover, this would need to be delivered at the 1300m altitude of the Bonneville salt flats, where ambient air pressure is 85% of that at sea level. While the production engine requires a boost pressure of 1bar, the two engines installed in the JCB DIESELMAX require 5.2bar absolute at full power. The scale of this challenge can be appreciated in comparison with around 3 bar absolute for a diesel Le Mans racer, and around 4 bar for the turbo-era Formula One cars.
They are using a 560 kW engine.
So what is holding the thing back from getting to 400 MPH?
