I have in front of me a worm set which is prone to stripping the gears on the worm gear ( machined into the shaft ) It is an oil pump drive from an old Enfield Motorcycle
The shaft is made of a soft steel and its teeth ( worm gear ) appear to be fly cut into the shaft along the axis to the shaft ..ie at 90 deg to the centerline of the worm. With 12 teeth
The pinion is hardened and has a low helix angle 4 deg ... 1 start
Now my question is ..If the contact is sliding wouldnt it be better to have the worm gear teeth at a similar angle to the worm helix ie 4 deg to reduce the point contact, also wouldnt it be better practice to have 2 teeth in contact rather than only 1
I think that as this shaft wears it get to a point where a onetime overload , say when the oil is cold is enough to cause one tooth of the gear to fail
Thanks , this is the first time I have attacked a worm gear in anger , so forgive the questions
Stephen
Ps have read all the other threads on this
Stephen
