Worthington Pump 2
warrenrk
Agricultural
Jun 14, 2003
3
We have a Worthington Pump, Model: 0820, Serial: Y650869 1.5 x 2.5 x 6
I am trying to determine the max flow rate and have been unable to locate any information or curve.
I have dropped a querry to Flowserve, but so far no response.
Any guidance would be appreciated.
Thanks in advance.
What do you know? Do you know the maximum discharge pressure, it's rated head, pump speed, flange ratings and the power rating of the driver it is/was attached to?
It is possible to estimate capacity and head based on other parameters.
We might start with around 60-75 gpm.
Start typing.
"People will work for you with blood and sweat and tears if they work for what they believe in......" - Simon Sinek
Hi BigInch;
The pump is currently attached to a 7.5 HP, 3450 rpm 208/220 3ph Baldor motor.
I will see what what other info I can get off the pump in the AM.
Thanks,
Thanks TenPenny, just what I needed!
Not a problem, I try to keep old stuff around, i'm always looking for information on old pumps.
Thanks, that was much easier than I thought it was going to be.
