MUHAMMAD FAHAD RANA
Materials
- Dec 13, 2018
- 36
Item: Header Cooler
Construction Code: ASME Sec VIII Div-1 & API 661
Background:
Tube sheet cladded with SS316L (3mmm Min.)and Top/Bottom plate (SA-516 Gr.70N) has to be welded with tube sheet. Header require to be PWHT as per API 661 requirement. See attached Sketch for Joint Detail.
Scenerio-1:
Qualify P1 to P1 WPS/PQR with using root and hot pass with ER309L and rest passes with ER-70S3 & E-7018 H4R to complete the joint and then proceed with PWHT.
Scenerio-2:
Qualify PQR P1 to P1 with ER309LMo filler wire start from Root to Final Capping pass and proceed with PWHT.
Scenerio-3:
Qualify PQR with Butterd layer on Carbon steel proceed with PWHT and after that complete the joint with ER316L.
Please share me your technical thoughts in case to use filler wire combination in actual.
Fahad
Background:
Scenerio-1:
Scenerio-2:
Scenerio-3:
Fahad
