stretched2thin
I'm trying to calculate the assymetrical offset for a L-L-G fault and am not totally sure I'm understanding things correctly. If you look at the sequence diagram for a L-G fault and the Thevenin equivalent circuit for a 3-phase fault, it's easy to see how the X/R ratio is defined for each. However, when you look at the sequence diagram for a L-L-G fault, it looks like I1, I2, and I0 would have different X/R ratios according to their respective Thevenen impedances.
Am I thinking about this correctly?
