XYZ point locations on a drawing 2
Jimmyv44
Automotive
Does anyone know of a company that writes GRIP programs or Journal files? My company needs a program to label XYZ point locations on a drawing. We are using the drawing for electrode locations so we also want it to label the component that the points belong to on the drawing. I know it is possible, but I'm not sure of the best way to do it. We currently copy and paste from the listing window, but it is very time consuming and errors get made too often. Any suggestions would be greatly appreciated.
Frank,
There was nothing in the .zip file. Can you please try it again? Thanks.
Thanks Frank. It is a good start. BTW, We are running 7.5.5.4.
I don't understand why the leader goes out in space when you place the numbers on a drawing though. I think it is something to do with the view? I think we also want to add a line for the trode name.
As the program stands it works as a demonstration program for the following limiting conditions.
The selected point cannot be selected using the often normally used inferred point option. This is because with the inferred method we get the drawing view and not the model view. Since we need model point data this could give us errors. It also gives us an error in terms of the label attachment point since here we need to convert the model data to drawing data since the label is placed on the drawing. If you take care to use a point selection method which ensures it is a point on the model then it should work OK.
Having said this I should have you check the nx8 version of the program which I have attached. In this case I needed to expand the drawing view to select the model point. I typically dont worry about release updates which may be part of the answer.
I dont know what "trode name" is but it would be simple to add an additional line.
Frank Swinkels
 http://files.engineering.com/getfile.aspx?folder=5ec7015b-a526-4638-8d7f-7112eb7249ca&file=xyzlabelsNX8.zip
Thanks Frank,
The Trode name is actually the component name. Do I need programing software to add that line? What software would I need?
What I meant when I said add an extra line I was referring to an extra line for the boxed label. That is the program would need to get the component name, determine a new length for the boxed label, resize the exising box and add the extra line (for the component name text). Now I think this should be done off-line. However as I understand it I cannot display my email address.
Frank Swinkels
Here is your program revised. It only contained one error. I also made some changes so that it reads better (I feal). I have also made a change and left the equivalent code commented out.
Code:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module pointsInfo_fbs1
    Sub Main()
        Dim theSession As Session = Session.GetSession()
        Dim ufs As UFSession = UFSession.GetUFSession()
        Dim response2 As Selection.Response = Nothing
        Dim pnt2() As Double = {0.0, 0.0, 0.0}
        Dim selectedObjects As NXObject() = Nothing
        theSession.ListingWindow.Open()
Start1:
        response2 = selectPoints(selectedObjects)
        If response2 = Selection.Response.Cancel Then GoTo End1
        Dim info As String = "Number of selected objects = "
        info = String.Concat(info, selectedObjects.Length)
        theSession.ListingWindow.WriteLine(info)
        For Each sda As Point In selectedObjects
            theSession.ListingWindow.WriteLine("X= " & sda.Coordinates.X.ToString("N4") & _
                                               " Y= " & sda.Coordinates.Y.ToString("N4") & _
                                               " Z= " & sda.Coordinates.Z.ToString("N4"))
        Next
        'For Each sda As Point In selectedObjects
        '    ufs.Curve.AskPointData(sda.Tag, pnt2)
        '    theSession.ListingWindow.WriteLine("X= " & pnt2(0).ToString("N4") & " Y= " & pnt2(1).ToString("N4") & " Z= " & pnt2(2).ToString("N4"))
        'Next
        GoTo Start1 ' Continue selecting points
End1:
    End Sub
    Function selectPoints(ByRef selectedObjects As NXObject()) As Selection.Response
        Dim ui As UI = ui.GetUI()
        Dim mask(0) As Selection.MaskTriple
        With mask(0)
            .Type = UFConstants.UF_point_type
            .Subtype = UFConstants.UF_point_subtype
            .SolidBodySubtype = 0
        End With
        Try
            Dim resp As Selection.Response = _
            ui.SelectionManager.SelectObjects("Select Points", "Select Points", _
                Selection.SelectionScope.AnyInAssembly, _
                Selection.SelectionAction.ClearAndEnableSpecific, _
                False, False, mask, selectedObjects)
            If resp = Selection.Response.Cancel Or _
               resp = Selection.Response.Back Then
                Return Selection.Response.Cancel
            Else
                System.Diagnostics.Trace.WriteLine(info)
                Return Selection.Response.Ok
            End If
        Catch e As Exception
            System.Diagnostics.Trace.WriteLine("Problems selecting objects.")
            System.Diagnostics.Trace.WriteLine(e.ToString)
        End Try
    End Function
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image immediately after execution within NX
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
    End Function
End Module
Frank Swinkels
