Y-Strainers
Yash Patel
11
My requirement for Y-strainer is CS SW 800# but the supplier is offering CS SW CL600. What is the difference? I think CL600 is only used if you want it flanged end and 800# API is used for NPT and SW. Am I right?
See this and scroll down a bit to see the class 800 stuff
Class 800 is not a tabulated ASME designation but is widely used apparently for SW and thread end valves and apparently defined in API 602.
It is somewhere between class 600 and 900 so a class 600 item will have a lower pressure rating than a class 800 one. If all you need is a class 600 rating (100 bar at ambient temps) then you'll be ok.
The line design pressure is 50psig. Class 600 rating should work, right??
Yes. CWP for class 600 is 1450 psig
I am curious that why CL600 was specified for the SW part. I suppose that the SW Y-strainer can be made per CL600 pressure rating, i.e. 1450 psig, but why not just 800 psig?
