We have to install a pump to pump out gasoline with traces of water from an open sump. Density of the liquid is around 600 cu. m/kg. The NPSH is zero and the discharge pressure is 6 bar abs and the flow is 5 cu. m/hr . The pump should should not be a vertical type which is a constraint. Like to have a suggestion to what type of pump is most prefferd to this application and any vendor's name to contact. It can be either positive displacement or centrifugal type.
