zero reaction force in ABAQUS/STANDARD Contact simulation
cyano84
6
Hello everyone,
I am running a load controlled spherical ball contact on a plate. I am using an axisymmetric model of the plate and axisymmetric analytical rigid ball. The plate is simply supported on the edge, so U2=0 on the bottom rightmost node on the plate.
I have a RP (reference point) at the center of the ball where I am applying a small displacement at first to establish contact and then load after removing the initial displacement. The analysis is running till completion but I want to extract Reaction Force at RP, which is always 0! Obviously that is not possible. What am I doing wrong?
Thank you for your help! - Sayan
Check the reaction force at the restraint as that will be equal to the reaction force of the RP.
What do you mean by "at the restraint"? The reaction force at the RP is 0 and also at the contact point i.e. top leftmost node where the initial contact is happening.
Thank you so much! The RF at the restraint is exactly equal to the applied load. I am happy now :)
The reaction force at the RP was probably zero as the internal forces of elements sum to zero in a static analysis, except where there's an imposed displacement/restraint.
Right. The reaction force at the contact point is also 0, which was throwing me off. In fact RF=0 pretty much everywhere except at the restraint. I guess if I want to calculate the reaction force at the contact, I have to calculate the contact stresses and work it out from there. It is probably treating it as internal nodes and not showing any RF.
