cyano84
- Jun 18, 2013
- 6
Hello everyone,
I am running a load controlled spherical ball contact on a plate. I am using an axisymmetric model of the plate and axisymmetric analytical rigid ball. The plate is simply supported on the edge, so U2=0 on the bottom rightmost node on the plate.
I have a RP (reference point) at the center of the ball where I am applying a small displacement at first to establish contact and then load after removing the initial displacement. The analysis is running till completion but I want to extract Reaction Force at RP, which is always 0! Obviously that is not possible. What am I doing wrong?
Thank you for your help! - Sayan
