Standard Broom Threads
MikeMech
92
Does anyone out there have specs for threads on standard broom handles? I have two different thread sizes, both appearing to have something close to ACME thread profiles but not standard TPI.
Most popular is about 3/4" outer thread dia x 5 TPI.
Another flavor is about 1.080" outer thread dia x 4 TPI.
I have to spec internal threads for parts that will accept these broom handles. Any help is appreciated!
I whipped down and into the janitor room to take a peek. Buddy put a piece of cardboard between the screw and the nut and then wrapped a piece of duct tape around the mating joint, Red Green style.
I don't think he got an engineering specification to complete this. So far, I've heard of no casualties.
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
Have you tried tracking down taps and dies used for wooden items? I remember seeing these sold in years past.
As you state there are several thread sizes for handles but I've always been told that 3/4-5 ACME is the standard thread form in the US.
Manufacturers take a lot of liberty with this thread. Most of the metal and plastic threads have very loose tolerances and form, especially the plastic ones.
Here is a company that supplies handles to a local manufacturer. You might get some information as to the standard "Standard".
Thanks for your help. It is indeed 3/4-5 ACME. I verified by checking thread profile on a machined part, which had a much better tolerance than the wood, plastic, and cast metal parts I'd been checking.
I figured that there would be a MIL spec along the lines of "Handle, mop, wood", and in fact there are, however they all included various gizmos for attaching a string mop directly. No spec for threads.
