Cromaney
- Oct 19, 2006
- 4
Is it necessary for water lubricated vertical turbine pump line shaft bearings be immersed in water prior to starting the pump? I have a vertical turbine pump that is water lubricated and has experienced a failure in the “foot” check valve such that the pump column pipe drains down to the static water level after the pump is turned off. This exposes the line shaft bearings in the top 80 feet of the pump column to air. Prior to starting the pump the line shaft bearings are not lubricated for 5 to 10 seconds as the pump column fills with water. This pump could operate 3 to 4 times an hour during summertime water demands. Any input or experience on this subject would be greatly appreciated.
