Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
MikeHalloran said:The latest buzz-phrase is "stage gate process". It describes how managers and lawyers think product development works. Basically it posits that you develop a spec describing what your product needs to do, and go on to designing the details only when the spec is correct and complete.
Engineers know that real product development doesn't, and CAN'T, work that way, because you never know what the final product is going to look like, in an engineering sense, when you start working on it. Engineers who work for managers don't admit that publicly, of course.
So to be successful, you need a crew of managers and pseudo-engineers out front, running through all the steps of the stage-gate phony baloney process, and in the room behind the back room, you need a bunch of tinkers beating on the product, building and destroying prototypes as fast as they can, evolving toward a solution that you eventually document as 'the spec', and feed to the front end of the process out front.
All of the visible documented processes work like electrical filters with an extremely high Q. In order to get anything out of them, you have to feed either a narrow signal of _exactly_ the right frequency, which is practically impossible, or you feed them with a broadband signal having substantial energy at all frequencies, and whatever happens to fit the filter gets through.
