In the case where the grade slopes I spec step footings to create a situation where the footings are always the required min distace below grade at all points. The steps by code are a max 2' rise and a min 2'run. A contractor wants to set the footings on a slope to match the slope of the grade outside so that the footings are founded the required distance below grade at all points . Does anyone have a problem with that.
