spinner1
- Oct 19, 2000
- 1
My father being a civil and structural engineer thought I should post this question in Eng-Tips and see if the results were consistant with his.
I've purchased a house built in th 50's which has a 4" thick horizontal concrete slab as the garage roof (fall out shelter I guess). The size of the slab is 22'x14' with minor spalling occuring. The slab is bisected equally on the underside with 1 concrete crossbeam whose thickness is 6.5"x6.5". There is minor cracking in the beam. The whole slab is supported on the perimeter (garage walls) by standard cinder block and an outer layer of your typical red looking concrete house brick. My question is(finally here), what is the maximum load this concrete slab will support? There's a door that leads from the 2nd floor out to it but I have yet to venture out. Your answers would be much appreciated as my father graduated Queen's University in 1956 and it would be of interest to see your results compared to his. I would also be grateful of the advice. Thanks for your help Eng-Tips!!
Spinner [sig][/sig]
Spinner [sig][/sig]
