PRuggiero
- Oct 8, 2007
- 64
Guys,
I've read a couple posts here about surface profiles with no datums but I'm still a little confused. I found this post by Jim (MECHNORTH):
By "best fitting" one can shift the workpiece about its 6dof to find the best fit of the workpiece within the maximum & minimum boundaries (i.e. offset geometries from the basic dimensions) to qualify the part.
So if I had a simple block part, datum A is a face, Datum B the longer edge and C the short edge and I had a profile callout on say the edge opposite of datum B without referencing any datums how would it get inspected?
From the post above it seems that if I placed the surface representing datum B down on a granite table and measured the distance that the basic dimension gives to the surface I am profiling, this would give me the "line" that my profile tolerance would be centered on, correct? Then I am allowed to move the part however I want to get that surface to fall within the profile tolerance.
Pete
Pete
