1. I have a situation with a 60 year old one-way slab and beam concrete building where the floor load in an area is being increased. It is causing torsion in an interior beam as the live load significantly changes on one side of it to the other. The beam has open stirrups and ACI requires closed stirrups to meet a certain level of torsion when it is compatibility based torsion. FRP would require fully enclosed wraps to resist torsion or partial wraps with anchors through the top portion of the beam connecting the FRP at each side, which I’m not real sure about. Are there any other options for torsion strengthening you have seen before?
2. Also, does anyone else skip the live load to see the effects of torsion on interior beams as a general practice?
