cliff234
- Aug 28, 2003
- 381
When computing the development length of 90-degree hooked bars in tension, ACI 318-14 permits a 0.70 reduction factor on the development length when there is at least 2.5” of cover measured normal to the plane of the hook (i.e, side cover) and when there is at least 2” of cover “…on the bar extension beyond hook”.
The wording has been like this for at least 20 years. What is “…2” of cover on the bar extension beyond hook”? Is it 2” cover past the tip of the hook (as shown in option B on attached sketch) or is it 2” cover from the hooked leg to the edge of concrete (option A), or is it something else? The wording is confusing to me.
