greznik91
- Feb 14, 2017
- 186
Im dealing with a RC frame building. There is a RC slab above - 200 mm thick.
RC slab:
Columns supports are pinned.
All connections between column - beam are modeled as a moment connection.
That mean that bending moment is transfered from end of the beam to a column.
Based on spans I think my yellow columns are pretty small in cross section dimensions (300/1000 mm)
I have made some calculations and its barely OK but my gut feeling is not good at all.
Your opinion?
Also - since columns/walls are pretty close together, I think the best way to go is to make continuous footings instead of spread footings connected with foundation beams.
RC slab:
Your opinion?
