dragonfire613
Aerospace
- Aug 22, 2013
- 7
We have several drawings that use a combination of two general notes to define a part, as follows:
(1) "THIS DRAWING SHALL BE USED WITH MODEL <CAD MODEL FILENAME> FOR COMPLETE PRODUCT DEFINITION. MODEL FEATURES ARE NOMINAL."
(2) "ALL SURFACES ARE (PROFILE SYMBOL) .060 UNLESS OTHERWISE SPECIFIED."
For this discussion, we will say the drawing itself has no further dimensions or feature controls, so the part is completely driven by the 2 above notes and the cad model.
After years of doing things this way, a new quality inspector is saying that in essence our notes are meaningless without datum references or adding "ALLAROUND OVER" to note 2, and that all parts will inspect as good no matter their geometry. I can say in the past, this was interpreted for a "best fit" using CMM meaning the model and profile tolerance generated a max/min envelope in which the part must fit.
Looking for more input on this. Searching through ASME Y14 seems ambiguous from statements such as 8.2.3 "Where the profile of a tolerance feature control frame is placed in a general note or general tolerance block, the tolerance applies to all features unless otherwise specified." To me theALL AROUND ALL OVER is implied... but maybe I'm wrong? QA states that as we have it, each surface is inspected independently of all others, allowing for things such as 0 thickness on ribs, etc. passing inspection.
Edit to add: Drawing also references ASME Y14.41. Essentially these are generally fairly simple parts, with perhaps a bit of GD&T within the model, but for this example I was more concerned with the general profile note.
