Dear experts
AISC Design guide-1 for design base plate and anchor rod is concentrated only on the applied axial compression plus moment loads, even in the two methods (uniform and triangle) of design the base plate, my question is , shall i use these two methods in case of axial tension plus moment or these methods are not applicable for this case .
Thank you
Thank you
Thank you
Thank you
