Edit Sketch Plane 1
McDesign25
23
Is it possible to change/edit the sketch plane when using the hole wizard? At times in the design process I have needed to change the sketch plane, and Solidworks will not let me. It seems this only occurs during hole wizard sessions. Is this a limitation of Solidworks?
Not like usual ("Edit scetch plane"), but you can simply drag-drop the hole wizard feature to a new plane. Select the hole in feature manager, hold down the left mouse button and drag it to the new face.
Bye,
Stefan --
unofficial german SolidWorks helppage
Shareware, freeware, tools and macros
Thank you Berlitz. I simple Control+C on the hole wizard feature, and then select the new face and Control+V. Very easy. This will definitely save some time.
Thanks again
yeah there is a way to change the sketch plane off of a hole wizard, before you create the hole using the hole wizard, make a sketch point on any surface, your sketch point will control the location of your hole, fire up the hole wizard, (note when doing so don't click on any surfaces, you need the hole wizard to create a 3d skecth)
when you have your hole that you won't you will lock the hole wizard sketch point onto your driving sketch point.
this will alow you to use edit sketch plane. hope this make sence if you have any quetions I will try and explain it better.
