Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
proliferation of homemade acronyms
* Yes, EN ISO 15614-1 (procedure qualification) does provide this (see your screenshot above). Mind that there is a clause for sl/ml with specific conditions. This makes it common to qualify a ml BW, sl FW and ml FW (unless you're working with <3mm plates/tubes).Spalding123 said:can a FPBW in plate also qualify you for a fillet Weld
retired13 said:When an acronym is present the first time
