MIStructE_IRE
- Sep 23, 2018
- 816
I have a short one way spanning transfer slab which supports a line load from a concrete wall above. This wall supports 3 storeys above and so the line load is significant resulting in high shear forces.
An outline sketch is included below.
The wall (line load) is not close enough to the support to benefit from shear enhancement.
The slab is supported by walls rather than columns so I have no punching shear issues, just slab shear. I have no issues with bending etc but the slab currently fails in shear.
My usual approach to slab shear is if it fails - its too thin! However in this case I have no option to thicken it due to architectural constraints. Has anyone ever put shear reinforcement into a slab? Personally I never have! Any thoughts would be great.
