Cavity volume as an input (rather than pressure)
biofriendly
Bioengineer
Jul 19, 2009
13
Dear all,
I would like to model a closed cavity with incompressible hydrostatic fluid inside.
The cavity is deformed in the interaction between the internal fluid being which is increased in volume by adding new water (at a known rate) and the external elastic interactions. The pressure is being measured. I know how to model the problem using fluid elements, using *static, and cavity interaction, defining pressure as an input. However, I would like to have volume as a control parameter.
I looked around in the manuals but I havent found any straightforward so far. Any ideas guiding me to the right direction?
Thanks a lot in advance...
A
There is an option to specify additional volume in a fluid cavity, maybe this could give you the form of control that you are looking for.
Thanks. Any chance you would remember the keyword? I tried fluid expansion but that didnt work.
This option can be specified using added volume parameter for *Fluid cavity keyword. So it should look like this:
*Fluid cavity, name=…, ref node=…, behavior=…, added volume=magnitude_of_additional_volume
I see that it is still not supported in CAE (which is not a problem but why I missed it). so much. Helped a lot!
One more question: I added the keyword. Nothing happens regardless of the value I assign to it. I removed the cavity pressure BC. Additionally, how can I assign to it an amplitude (added volume rate)?
Check the documentation chapter "Analysis --> Analysis Techniques --> Special-Purpose Techniques --> Surface-based fluid modeling --> Fluid cavity definition", it describes these options in detail. However, amplitudes are not supported in this case.
