Good evening fellow engineers,
I am looking for information regarding the swivel joint marked up in attached PDF. Is it just a hollow pipe with bolt going through it? or is it usually a pin inside a bearing and further enclosed inside pipe? Any information or breakdown of that joint will be highly appreciated
Thank you
Kaffy
Thank you
Kaffy
