pbailey
- Oct 31, 2022
- 11
Has anyone seen a beam like this? Whole box section is about 9-3/8" tall, 5" wide. Looks like a box beam/double channel from the inside. Has a #5 or #6 rebar in each corner and vertical rebar at the premanufactured hole. All welded up, but no concrete in sight. Hole is obviously premanufactured, not cut in-field, and 6" diameter. Used as the central load bearing beam of a house built in 2017. Any info/insight would be appreciated.
![Photo_Aug_25_2023_9_02_20_AM_h7othj.jpg](https://res.cloudinary.com/engineering-com/image/upload/v1692980013/tips/Photo_Aug_25_2023_9_02_20_AM_h7othj.jpg)
![Photo_Aug_25_2023_9_19_48_AM_cy5xuu.jpg](https://res.cloudinary.com/engineering-com/image/upload/v1692980014/tips/Photo_Aug_25_2023_9_19_48_AM_cy5xuu.jpg)
![Photo_Aug_25_2023_9_02_25_AM_rxqblt.jpg](https://res.cloudinary.com/engineering-com/image/upload/v1692980022/tips/Photo_Aug_25_2023_9_02_25_AM_rxqblt.jpg)
![Photo_Aug_25_2023_9_19_41_AM_csaz7d.jpg](https://res.cloudinary.com/engineering-com/image/upload/v1692980024/tips/Photo_Aug_25_2023_9_19_41_AM_csaz7d.jpg)
![Photo_Aug_25_2023_9_19_51_AM_zufvcm.jpg](https://res.cloudinary.com/engineering-com/image/upload/v1692980026/tips/Photo_Aug_25_2023_9_19_51_AM_zufvcm.jpg)
![Photo_Aug_25_2023_9_19_56_AM_r4zizv.jpg](https://res.cloudinary.com/engineering-com/image/upload/v1692980056/tips/Photo_Aug_25_2023_9_19_56_AM_r4zizv.jpg)
![Photo_Aug_25_2023_9_02_10_AM_vxon5f.jpg](https://res.cloudinary.com/engineering-com/image/upload/v1692980066/tips/Photo_Aug_25_2023_9_02_10_AM_vxon5f.jpg)
