I model this quite simple structure. A 1m tall column with 1000kN lateral load on top is sitting on a 1m wide slab as you can see below.
The design bending moment (-487kNm & +520kNm) in this 1m wide design strip looks normal to me. (see below)
However, in the design module, ETABS is using about +- 1000kNm as design moment as you can see from below.
What goes wrong here? It is a simple structure so no twisting moment obviously.
