Georgeineering
Industrial
- Mar 10, 2024
- 1
What would be the best way to weld some cracks on a thermal oil boiler coil? I was thinking 6011, but after some welding at 50 amps, it blows a hole and oil leaks out. Also did some tig with er70s6, but it spatter too much. Ive tried emptying all the oil that i can at the pump and outlet lines, but cannot get the oil completly out of the coil as it is thick at cooler temps.
Should i drill a hole at the lowest point and heat with torch to try and drain oil or is it common practice to be able to weld while oil is still inside the coil tubes?
Here is a picture to help understand the issue I'm having. The boiler is run 1t 160 centigrade and sends oil to radiators inside a oven.
