Hydraulic symbol identification needed, please.
F_Jacobsen
Industrial
Jul 18, 2024
1
I'm looking to see if anyone here can explain to me how the valve in question is controlled. I've circled it in blue on the attached diagram.
It's part of a vehicle scissor lift. So far I've been unable to find any information about it. I have a theory that it may be controlled by whichever side of the valve has the highest pressure, but I would like that confirmed or dismissed. Any help is much appreciated. Thank you
 https://files.engineering.com/getfile.aspx?folder=842b149e-a036-4b64-af6c-5f379a050398&file=Vehicle_lift.PNG
It's a manual control valve - rotary type
You turn the knob or lever to change which cylinder is operated.
Mobile Hydraulics
The valve also appears to have a variable restriction so I guess it is a single valve for speed and direction control of the cylinders.
