GD2
- Sep 25, 2017
- 652
Does anyone has any experience with the pneumatic actuated ON/OFF valve for the refinery FCC Column bottom slurry service?
Fluid handled:
1) CLO (Clarified Oil from main column bottom with VGO and residue)
2) Slurry content – Solid concentration – 132100 ppmw (solids are FCC catalyst, silica alumina based)
3) % of slurry – As above
4) Particle size - > 5 micron with agglomerates
5)Frequency of operation in day or per month – every 60-90 minutes.
Operating Parameters:
Liquid Slurry Oil +300°C Max, +288°C - 291°C Norm
Design Temperature +375 degc & Design Pressure 36.1 Bar(g).
Operating Pressure 0 to 20 barg, Max. operating 20 barg, Max. Dp = 20 barg
Actuator Sizing : 4.5 barg min.
Actuator Working pressure: 5.5 barg min. to 8.0 barg with max. Design Dp (20barg)
to ensure Opening under 500ms and correct operation
OPENINGTIME <400ms, with max. CLOSING TIME at 500ms
Response on what type of valve, brand name etc will be appreciated. Is a metal-seated ball valve suitable?
GDD
Canada
Fluid handled:
GDD
Canada
