errors in editing
multicaduser
Industrial
Jan 29, 2013
261
The frequency of these errors is increasing when trying to edit features. This is not part specific and part cleanup does not fix, only closing and re-opening the files and or session. The listing below shows an error very shortly after opening the session and only doing a few edits.
Has anyone seen this or understand what is happening?
Snip image of error (can be similar).
Snip from end of log file after the error.
&MACRO CUSTOM 25 PARTNT * TL_MENU_COMMAND * (7 13) * 0 * 18793 ! Text (41), MODL_MAKE_CURRENT_FEATURE
[[12264*]] pk_error_handler: got PK error 22
[[12264*]] PK function PK_FACE_ask_surf failed, ifail PK_ERROR_not_an_entity (22), severity Mild
[[12264*]] Failing argument face (1), entity 200456, index -1
*** EXCEPTION: Error code 820022 in line 1204 of o:\nx2306\ip1700\src\dman\no\ind\ki_errors.c at Fri Sep 6 05:48:49 2024 Central Daylight Time
+++ PK ifail 22 from PK_FACE_ask_surf
[ 1] 7FFF0A339CAD (libsyss)
[ 2] 7FFF0A33AAF4 (libsyss)
[ 3] 7FFF0A33ADD9 (libsyss)
[ 4] 7FFF0A2BF596 (libsyss)
[ 5] 7FFF0A2BD532 (libsyss)
[ 6] 7FFEA97280AA (libdman)
[ 7] 7FFE6662FD5C (PSKERNEL)
[ 8] 7FFE6662F061 (PSKERNEL)
[ 9] 7FFE6602C9BB (PSKERNEL)
[10] 7FFE76922A9C (libcmod)
[11] 7FFE7692F81C (libcmod)
[12] 7FFE6E308EF3 (libnxpos)
[13] 7FFE6E306A18 (libnxpos)
[14] 7FFE6E304766 (libnxpos)
[15] 7FFE6E2FD401 (libnxpos)
[16] 7FFE6E2F85C8 (libnxpos)
[17] 7FFE6E2F9377 (libnxpos)
[18] 7FFE6E2F8EB5 (libnxpos)
[19] 7FFE6E2FC662 (libnxpos)
[20] 7FFE7984DD9C (libdisp)
[21] 7FFE7984D9DF (libdisp)
[22] 7FFE7AB367F2 (libgraphics)
[23] 7FFE7AB369A5 (libgraphics)
[24] 7FFE7AB63E16 (libgraphics)
[25] 7FFE73BDBC42 (libocc)
[26] 7FFE73BDB4C4 (libocc)
[27] 7FFE73BDB637 (libocc)
[28] 7FFE7AB6366A (libgraphics)
[29] 7FFE7988B465 (libdisp)
[30] 7FFE7AB655E2 (libgraphics)
[31] 7FFE7AB63277 (libgraphics)
[32] 7FFE79755987 (libdisp)
[33] 7FFE79753209 (libdisp)
[34] 7FFE7975329E (libdisp)
[35] 7FFE728DC5E6 (libpart)
[36] 7FFE728DC8B5 (libpart)
[37] 7FFE728DC68D (libpart)
[38] 7FFE79752D7B (libdisp)
[39] 7FFE796760C7 (libdisp)
[40] 7FFE79675CB9 (libdisp)
[41] 7FFE7AB625C8 (libgraphics)
[42] 7FFE7664C305 (libcmod)
[43] 7FFE7664C3F9 (libcmod)
[44] 7FFE7664B8C0 (libcmod)
[45] 7FFE7664BDBE (libcmod)
[46] 7FFE7664BA5D (libcmod)
[47] 7FFE7664B4A8 (libcmod)
[48] 7FFE765F6AEB (libcmod)
[49] 7FFE7674BA3B (libcmod)
[50] 7FFE7674B64F (libcmod)
[51] 7FFE76749D3A (libcmod)
[52] 7FFE72C956A8 (libpart)
[53] 7FFE72C9EFBA (libpart)
[54] 7FFE72CA5B67 (libpart)
[55] 7FFE72C9DE0B (libpart)
[56] 7FFE72C946B2 (libpart)
[57] 7FFE76830E06 (libcmod)
[58] 7FFE7682F0C1 (libcmod)
[59] 7FFE7682BC4A (libcmod)
[60] 7FFE71A3EE61 (libpartmodl)
[61] 7FFE6B75B818 (libpartnavint)
[62] 7FFE6B758631 (libpartnavint)
[63] 7FFE6B75A21B (libpartnavint)
[64] 7FFE6B763C0A (libpartnavint)
[65] 7FFE6B78CF96 (libpartnavint)
[66] 02155767C428 (treelist)
[67] 02155767A470 (treelist)
[68] 02155768382E (treelist)
[69] 7FFE787E6F7E (libugui)
[70] 0215576798BD (treelist)
[71] 021557676B4D (treelist)
[72] 021557666FF1 (treelist)
[73] 7FFE9FF39072 (mfc140u)
[74] 021557678C33 (treelist)
[75] 7FFE9FF3886F (mfc140u)
[76] 7FFE9FF3610E (mfc140u)
[77] 7FFE9FF364D4 (mfc140u)
[78] 7FFE9FDD9579 (mfc140u)
[79] 7FFF1D52E858 (USER32)
[80] 7FFF1D52E299 (USER32)
[81] 7FFE9FF1EAF2 (mfc140u)
[82] 02154D02CB80 (windowsui)
[83] 02154D02D340 (windowsui)
[84] 02154D030513 (windowsui)
[85] 7FFE7C187C1D (libugutils)
[86] 7FFE78BD7239 (libugui)
[87] 7FFE78ADCBA1 (libugui)
[88] 7FFE78ADC9DC (libugui)
[89] 7FFEC45D0B6A (libuginitint)
[90] 000180006C6F (ug)
[91] 000180003107 (ug)
[92] 7FF7299F125E (ugraf)
[93] 7FFF1B9A7034 (KERNEL32)
[94] 7FFF1D7C2651 (ntdll)
>>>> Error code 820022 caught in file "o:\nx2306\ip1700\src\graphics\no\ind\dss_regen_common.c" at line number 247
>>>> Error code 820022 caught in file "o:\nx2306\ip1700\src\graphics\no\ind\gt_display_from_lists.c" at line number 1698
>>>> Error code 820022 caught in file "o:\nx2306\ip1700\src\disp\no\ind\dss_view.c" at line number 2708
>>>> Error code 820022 caught in file "o:\nx2306\ip1700\src\graphics\no\ind\gt_display_from_lists.c" at line number 1924
>>>> Error code 820022 caught in file "o:\nx2306\ip1700\src\graphics\no\ind\gt_display_from_lists.c" at line number 1952
>>>> Error code 820022 caught in file "o:\nx2306\ip1700\src\graphics\no\ind\gt_display_from_lists.c" at line number 1801
>>>> Error code 820022 caught in file "o:\nx2306\ip1700\src\disp\no\ind\Display_TaskBuffer_PartBuffer.cxx" at line number 318
>>>> Error code 820022 caught in file "o:\nx2306\ip1700\src\disp\no\ind\Display_TaskBuffer_Buffer.cxx" at line number 193
>>>> Error code 820022 caught in file "o:\nx2306\ip1700\src\disp\no\ind\Display_TaskBuffer_Buffer.cxx" at line number 107
>>>> Error code 820022 caught in file "o:\nx2306\ip1700\src\part\no\ind\Part_ContextRestricted_ProcessDisplayedParts.cxx" at line number 263
>>>> Error code 820022 caught in file "o:\nx2306\ip1700\src\part\no\ind\Part_ContextRestricted_ProcessDisplayedParts.cxx" at line number 551
OnError(820022): ProcessingManager has 2 PartNodes:
0: PartNode for part 60344 (7290_top_assembly) has 1 DisplayedPartProcessors:
0: DisplayedPartProcessor 0x00007FF426D02140 for client 'Display::TaskBufferProcessor' has been processed
1: PartNode for part 100957 (7290_a-assembly) has 1 DisplayedPartProcessors:
>>>> Error code 820022 caught in file "o:\nx2306\ip1700\src\part\no\ind\Part_ContextRestricted_ProcessDisplayedParts.cxx" at line number 850
>>>> Error code 820022 caught in file "o:\nx2306\ip1700\src\cmod\no\ind\cm_update.c" at line number 1764
>>>> Error code 820022 caught in file "o:\nx2306\ip1700\src\part\no\ind\update.c" at line number 10855
>>>> Error code 820022 caught in file "o:\nx2306\ip1700\src\part\no\ind\update.c" at line number 10978
>>>> Error code 820022 caught in file "o:\nx2306\ip1700\src\part\no\ind\update.c" at line number 9267
>>>> Error code 820022 caught in file "o:\nx2306\ip1700\src\part\no\ind\update.c" at line number 9398
>>>> Error code 820022 caught in file "o:\nx2306\ip1700\src\cmod\no\ind\frec_mcf.c" at line number 3038
>>>> Error code 820022 successfully handled and acknowledged
MESSAGE_BOX displayed: Fri Sep 6 05:48:49 2024 Central Daylight Time
&MACRO MESSAGE_BOX -2, Unable to replace current feature due to following error encountered:
&MACRO MESSAGE_TEXT Cannot finish operation
MESSAGE_BOX acknowledged: Fri Sep 6 05:49:09 2024 Central Daylight Time
&MACRO MENU, 0, UG_HELP_SYSTEM_LOG UG_GATEWAY_MAIN_MENUBAR <RibbonFileBar->BackStageBar->LeftBackStageGroup->rbn_file_tab_help_cascade.csb> ## !
NX 2306 Windows 10
I suggest running part cleanup with all the simple and moderate options turned on along with the "delete unused objects" option.
If that doesn't help, I suggest contacting your first level NX support.
www.nxjournaling.com
Thanks for the reply. Cleanup has been run several times without success, looks like a call to our var.
Have a nice weekend.
NX 2306 Windows 10
Imported model ?
If it is non parametric ( = imported) try the File -Export- Heal geometry.
it creates a new partfile with cleaned bodies, removed parameters.
If it is parametric , try the Optimize Face under direct modeling.
Regards, Tomas
The more you know about a subject, the more you know how little you know about that subject.
Also make sure 2306 is updated. It had some trouble with handling STEP models on release (1700).
Hi Bleaker, thanks for the information. NX on the system is in fact 1700, I'll check with our IT about this.
NX 2306 Windows 10
