Stainless 304 / 316 magnetic ???
Mechy
13
Austenitic Stainless Steel-- Magnetic ????
Stainless 304 or 316 is non magnetic. But if you put a magnet on a valve body or fitting of the above materials, the magnet sticks to it (although with less force than carbon steel). Also, if you try to stick the magnet on a straight length of pipe of the above materials it does not stick to it at all.
Could this (magnetic nature of 304/ 316 fittings/ valves) be because of the forging (?) process. Can anyone shed light on it ???
Yes - 304 and 316 can be magnetic - go into the search field on this page and type in "304 magnetic" and you will see a number of threads already on this topic.
a commonly repeated question, and one repeatedly answered.
yes it is magnetic under suitable conditions.
If the valve body is cast, then it will have a lot of ferrite and be somewhat magnetic. Wrought 304 or 316 usually only shows ferro-magnetic response when it has been cold worked or welded.
Check the following threads:
thread330-53777
thread330-35718
