Statistics in Excel
gb433054
Aerospace
Jul 24, 2003
28
Hi
Could anyone tell me if there is a Free addin for excel that will let me plot a normal distribution curve, histograms etc. Any help will be appreciated
Dave
If you go to the menu Insert|Paste Function, there is a selection of statistical functions available already in Excel.
Also, try using the Help function.
TTFN
I have tried that, but it only gives you the value of the normal distribution and std dev. I want to plot a distribution curve for a sample of data. However there doesnt seem to be the facility to do so.
I'd start out from Insert|Chart|X-Y scatter
Good Luck
johnwm
________________________________________________________
To get the best from these forums read faq731-376 before posting
gb433054,
what you need to do in install the analysis toolpak that comes with excel.
from menu, select: tools-addins
select anaylsis toolpak and analysis toolpak - vba.
once add-ins are installed, from main menu, select tools-data analysis and you will find all the statistical information you requested.
good luck!
-pmover
I don't think the toolpak will give you the ability to automatically graph what you want. I have gotten a commercial product which I feel works well, QI Macros. It is a very good SPC Excel add-in. Its available at
The "histogram analysis" function in the analysis toolpack will what you mention allthough its not very elegant. I think you must do the std. plot yourself (also the transformation because excel dont have a plot with std. dev. axis).
Best regards
Morten
In order to get the plot, you will have to enter the discrete X values of the coordinates in one column or row, then calculate the probability mass function based on your statistics and each independent X in another column/row. Then make a chart with those two arrays as the inputs.
Hope this helps!
