12 Volt vs 24 Volt diesel engine 2
ro_kru
33
In diesel engine we have 12volt and 24volt battery system. I am wondering for any application of diesel engine, how can we decide whether we need 12volt or 24volt diesel engine? What are the deciding factors about it? I can understand that by increasing voltage we can have more power, but why we need 24 volt over 12 volt?
[pre]
Tugboateng said:
Batteries mostly come in 2.1v flavors
[/pre]
Per cell, yes. For the vast majority of Diesel engine starting applications, 12V batteries are used and connected in series for 24V (when the system is 24V).
Enginesrus said:
Heavy trucks in US start on 24 volts.
Many years ago, yes. Anything built in the last 30 years will be 12V start.
Littleinch said:
Irbcan - Define "Truck".
For the purpose of this discussion I meant class 7 and 8 truck. Most Everything on the road these days is 12 volt anyway.
Fair enough. There does seem to be a bit of US Europe divide on this subject.
Wait until 48V becomes more common! Both car and commercial vehicle sectors are applying it particularly to hybrid powertrains and WHR [waste heat recovery] systems in CV's.
I believe you are thinking of 480v hi voltage systems, which are commonly still controlled with 12v lo. College professors and the media have been predicting a lo voltage change for 20+ years, still haven't seen it tho for the obvious reason - no benefit and plenty of cost.
No, I did mean 48 volts not 480 V. Take a look at the DOE Supertruck program and you will see them using 48V for the electric PAS, air compressor, and WHR.
Not on top of this topic myself, but I note that the North American auto industry switched from 6v to 12v during the 1950s.
TugboatEng said:
An interesting note, one of the reasons 24 volt never gained popularity for automotive applications is that the filaments for the light bulbs are much thinner and couldn't tolerate bumpy roads.
All solved by LEDs these days.
je suis charlie
