ScottyUK (Electrical)
Thanks Scotty, I did actually read up on the cord size/fuse ratio. But I'm also wondering about damaged induced as a result of the lack of power and how such an appliance later deals with a power surge. Normally an appliance that is under powered will begin to under perform and eventually just stop working. For the record, the Hotpoint was a 13 amp fridge.
I think, here in the US, lawsuits have conditioned manufactures to use a more robust power cord on major appliances. I don't know if I mentioned it here or elsewhere but increasingly the UK is encountering situations that come about because incoming populations are accustomed to using primitive solutions to what, for many has been a frequent problem in the old country. Hence doing something like running a heavy gauge of wire across the fuse gap, might strike them as a simple way to deal with KCTMO not solving the power problem in a reasonable time. Crazy to you or me but Old Country Know How to a handy guy with a little knowledge. The tenants described the lights flashing on & off or up & down intensely for weeks prior to the outage. So it comes down to duration and amperage. If they had "power spikes" as well as surges and the spikes were below a certain amperage, then the fuses would not blown. It takes 0.3 seconds for 100 amps to blow a 13 amp fuse. But how many blown fuses from power surges or spikes can an appliance take before it is compromised? But I labor the issue. I'm really adamant that the investigation into the cause of the fire, also look at the condition of the remaining building wiring and appliances, the repairs by KCTMO in May/June 2013 and also the quality of the power delivered to the rest of the area. Since the surges seemed to be something that occurred at night, the power delivered needs to be examined as well.
Do you think it likely that a tower flat built in the early 70's had ring circuits, possibly shared ring circuits? And what about aluminum wiring? What happens on a shared circuit if just as your refrigerator motor draws a heavy current, your neighbors washing machine turns off? Is it like the poor soul in the upstairs shower that gets fried when the downstairs shower is shutoff?
