Air/air vs Water/air intercooling.
rpmag
Automotive
Oct 15, 2004
105
Laminova (Opcon): clain good performance and they are certainly an unusual thing to hold in your hand, with such slim fins and tight tolerances.
Can anyone suggest some shortcommings from such a design? How would such a system avoid the heat soak issues that afflict an air/air IC in motorsport?
The fins appear to be cut from the solid; I'd guess an occasional chip might appear downstream.
The air passages are necessarily circuitous. The air flows through a number of relatively long semicircular channels that each measure 0.3mm x 3 or 4.25mm. They do not claim low pressure drop on the air side.
Look closely at the last illustration in "intercooler.pdf". Notice how much smaller the cross- sectional air flow area at the cooler entrance is than the cross- sectional area of the intake manifold in the illustration. I.e., the packaging density that suits the technology well to liquid- liquid cooling may not accrue in liquid- air cooling. The intercooler application appears to be conjectural; I'd expect a developed version to occupy substantial volume.
Mike Halloran
NOT speaking for
DeAngelo Marine Exhaust Inc.
Ft. Lauderdale, FL, USA
The fins look too small to me to be that efficient and the route for the air flow looks a bit to tortuous to be "Pressure drop" thrifty.
Take a look at Titan-lite.com
Extremely accurate, with the benefit of filling the hole unlike the cylindrical units from Laminova.
