beattsmjk
- Apr 15, 2009
- 40
- 0
- 0
Hi Could someone please offer some advice?
We are supplying this cheapish compressor to one of our customers. They are a small bakery and need a back up air system to run our liquid handling machinary when the compressor they share with the factory next door is swiched off at night!
We will plumb it in with a Non return valve and set the pressure slightly lower than the main compressor.
My problem is this, the compressor in the link comes with a manual drain tap / plug (underneath) which must be opened every 24hrs to drain condensate from the tank.
I dont think our customers will do this. They may start off with the best intentions, but my feelings are that after a month they will become a bit more carefree if you get my meaning.
Is there anyway I can fit some sort of autodrain to the compressor to eliminate the need for a manual daily draindown?
Apparantly, according to Machine mart, the compressor should be switched off when it is drained.
The compressor will be lightly used. Probably operating 20 litres of air every 15 mins or so at 5 bar.
The link
The link
