Hi
I need to fasten a force sensor to an aluminium plate of 20mm thickness. The manufacturer of the sensor provides that it should be fastened with two bolts M12 12.9 with a torque of 130Nm onto a plate made of stainless steel (20mm). Because of the weight I can only use an aluminium plate.
My question now is: how to I know if the threads in aluminium will withstand the torque of 130Nm.
Thnx in advance
Thnx in advance
