Dear member
Q : How could I have a cumulative result at the end of Transient –full Analysis?
Problem:
Let’s we have two loads acting on a cantilever beam, say F1: as a initial load & F2: as a new load.
If we apply F1 & F2 separately we have displacements D1 & D2, respectively. (for a node of the structure).
I use Transient-Full analysis, & use IC commands for establish initial condition caused by F1 (based on ANSYS-9.0 help files) used a small dummy time (=T1), two substeps & TIMINT.off and apply F2 as added load to system with a time T2. After each step the result was written in LSWRITE & finally used LSSOLVE to solve the loads cumulative.
Result is not cumulatively. I see a stepped result! Displacements from D1 at time zero changes to D2 at the end of T2 !
I expect D1 at zero time (as initial condition) & D1+D2 as a final result.
May you help me?
Thanks in advance
Amini
