Hi Guys,
I'm a newbie here, so I hope I don't step on too many technical toes in this message.
I would like to respectfully disagree with all of the given reasons why trailer frames are cambered. I think the real answer is something else.
Everything wears out. Tires wear, brake linings wear, brake drums wear out, light bulbs burn out, paint wears out, and believe it or not...trailer frames wear out! Trailer manufacturers realize that over extended time/miles/bumps/overloading the frame rails will tend to relax. So to make their frames last longer, they are built with a positive camber. The more camber, the longer the service life of the trailer.
Having some engineering background, having worked for a small volume trailer manufacturer and having been around the trucking industry, all cause me to believe in my above stated opinion regarding trailer camber.
In the trucking industry, a flatbed trailer that has lost its camber is called a "sway-back". I think the term is a carry over from the old west describing a horse with a bad back. Sway-back trailers are not very valuable/useful/desirable in the trucking industry, ie the service life is out of them.
Many times trailer frames are made out of T1 steel which typically comes in plate form. T1 is much stronger than A36 steel which I beams are commonly formed from. So to make a strong trailer frame, 3 pieces of T1 steel are used, the top flange, the web, and the bottom flange. A good trailer manufacurer welds all 3 together with a certain amount of camber. Trailers made from A36 I beams are not strong and are heavy. Heavy equals less payload. However on some applications like the skeleton frame under container boxes the frames do not carry much weight and therefore can be made out of the cheapest steel available (usually A36). Container boxes are self-supporting and focus their weight to the hard points in the corners which are typically immediately above the fifth wheel and rear axles of the trailer hence the trailer frame bares no weight.
As you notice flatbed trailers on the road, look to see how they are loaded. Let me give you an example using bricks. I good driver will have 2 piles of bricks on his trailer. The first bunch will be as far foward as possible (above the fifth wheel) and the second bunch as far back as possible (above the trailer axles). This method of loading puts the least amount of load on the middle of the trailer which stresses the trailer frame the least which causes the trailer to last longer. A poor driver puts all the bricks in one bunch and in the middle, stressing the frame the most and "wears out" the frame slightly faster than the good driver.
Lastly, being somewhat associated with the trucking industry in the past, you guys have seriously overestimated law enforcements ability to detect overweighted commerical vehicles. Weighmasters and police are really inexperienced regarding this topic. With cambered trailers and air ride suspensions, it is almost impossible to detect an overloaded vehicle. The only thing to look for is the amount of tires are squatting...and this is difficult thing to do visually. And with cb radios, cell phones, and truckstop gossip, many overloaded trucks bypass scales and/or pass by scales when they are closed. The overloading issue is furthermore confused because different states have differing weight laws. The whole thing is a colossial governmental reglatory mess, ie tax dollars at work.
Anyway, these are my thoughts, I could be wrong, (heck...most of the time I am wrong) but I think the bending/cycle fatigue/service life of the frame rails is the primary purpose for the camber.
Wayne
bulldozermaki@gmail.com
