Area Replacement Rule, WRC, and FEA 1
sxz
40
Hi, I have a nozzle reinforcement calculation. As per the UG-37, the area replacement rule, Aa < Ar, it fails, but WRC or FEA results pass. Can I use the WRC or FEA result for fabrication?
Thanks.
Ok, the old order before design gamble. Can you put internal projection? Even 1" should do.
Yes, it works. It is a better option than adding a repad.
