jayinwww
Petroleum
- Sep 20, 2018
- 25
Our company has been asked to cut out some mixer 7mm plates from inside a mixer, these are non-pressure components that are welded to the shell, we will cut the plates 1" from the shell and not touch or weld on any pressure boundary. Since we are cutting these mixer plates, when we put that back in, they will now be full pen welds. I understand this is not structural steel, which structural steel may require UT, backing plate, or grind out the root and reweld etc. Since this isn't structural steel code. Is there typically any addition NDE requirements for a full pen weld for ASME Sec VIII Div 1 non-pressure plates inside a mixer? We just have been asked to do PT on the final welds.
