I would like to build a SB Chevy engine to run as an Atkinson cycle engine. By Atkinson cycle I am referring to high compression with late intake valve closing. Pump premium gas. I am willing to live with reduced power output for a slight increase in efficiency. Can anyone provide a starting point for compression ratio v intake valve closing point? Advertised or @ 0.050" lift. I can taylor the ignition timing for RPM and MAP but I need to stay out of the CI range. Thanks for the help.
