Attempted Taxiway Take off
If I tried to do that the machine would be yelling at me "not a runway" as soon as the ground speed goes over 35 knots or the power levers get pushed up more than 45 degs.
I haven't seen the system available for a 737. Airbus have it.
How does it know?
But you can't compare a machine built / designed in the 50's and 60's with one designed in the 90's or later.
Hell the 737 doesn't even have overwing exit slides....
Disclaimer: I know absolutely nothing about aviation.
That little photo caption at the end implies that this happened because a private jet cut the plane off. It felt shoehorned in there; it’s not addressed in the body of the article. Is Fox diminishing that fact?
It gets a feed from the GPS and ECAS. It gets upset when your GPS jammed.
Proper Airbus is 1980's but has a common databus for system data and position.
I think it was developed around 2005.
They added two incidents into the same report. The other was a runway incursion at Chicago
Apparently supposed to ne 17R and ended up on the taxiway immediately to the right (H) with the next one was G.
Now how they missed the large stop lines is unclear, or the white stripes or all the rubber.... It is a big airport in all fairness
Agree Fox cramnmed two recent events into one article.
Lack of "Spatial Awareness" again
Air Canada 759 nearly caused the deadliest airplane accident in history when it attempted to land on a fully occupied taxiway. I don't know that there were any repercussions for the pilots.
59 feet above ground. They were only 15 feet above the aircraft on the ground. There were 4 planes loaded with passengers on the taxiway if I remember correctly. It didn't even get reported initially. Something is really off about that story.
I wonder what it was like to be in the jets on 'taxiway' when full throttle turbojet/fan dumping it all towards the sheet metal roof about 15' above your head?
