Automatic Scaling of EXCEL Drawings
alan54
Chemical
Jun 20, 2001
23
I'm using EXCEL 2000. Can you use the built in drawing feature and have objects scaled based on values in cells.
For instance, for a rectangle, you can right click / Format Autoshape / and change the height, width, etc under the Size tab.
But to set those equal to a cell value in VBA, I can't find the rectangle's object name (i.e. rectanglename.Width = value of cell)
Many Thanks,
alan54
response to first question - unfortunately not or not that i'm aware of.
2nd question: try the selection.
with regards to a scaling factor, please note the code below used to change an object's size. instead of the textbox1.value, change code for a cell input. the code below is not in its entirity as i appreviated what the sub is actually used for. be certain to have object selected.
Private sub CommandButton2_Click()
on error goto no_selection
wid=selection.width
hei=selection.height
sf=1+textbox1.value/100' change to sf=range("sf").value or ?
selection.height=sf*hei
selection.width=sf*wid
exit sub
no_selection:
end sub
interesting, but ...
-pmover
You can refer to any shape on a worksheet by its name, through the Shapes collection.
ActiveSheet.Shapes("Rectangle 1").Height
You can read/write all relevant properties in this manner, so in your case ActiveSheet.Shapes("Rectangle 1").width = Activesheet.Range("A1").Value
The width/height etc. are specified in points = 1/72 inch. Regards,
Joerd
