Axial Impeller/Propeller
GarySandStorm
4
Hi there, I have been researching this for some time now since the company i work for only recently stepped into the realm of the Axial flow pump and i was the lucky one to be given the task of theory gathering lol. BUT All the books and papers I have gone through use example of curved blades with some angle of attack, using aerofoil or Bernoulli theory. So I would like to know what to use when assuming the propeller blades are flat(not curved) at an angle to predict to extent the performance. IF at all possible?
Any light or direction on this would be so Great :D
Thx
Gareth Sampson:- Cheap W*ore oops! I mean Intern.
Assume the impeller/propeller to be a perfect screw. Pitch times velocity (rpm) times area equals volume. Multiply slip factors (pulled from thin air), and you have flow rate against negligable head. In short, a good CFD run would probably shed better results, but knowing max capacity is worth at least a lunch.
Mike Cool
Mechanical Engineer
American Stainless Pumps, Inc.
Los Angeles California USA
Figure on a slip factor of 80% at max power.
Cheers
Greg Locock
I rarely exceed 1.79 x 10^12 furlongs per fortnight
If you are trying to get your mind around axial pumps, read this thread.
thread237-262245
Don't pay any attention to any of the back and forth, just the technical information. I think you will learn a lot.
rmw
Thanks for the replies. The Info is very helpfull :D
Nice to see someone drinking water at work instead of the usual coffee.. hhmm water? oohh eerr! yeah sure, this some gooood "water" he he he
